XM travel link
I recently bought a 2014 GMC Sierra 1500 that was supposed to come with a icon on the home page for fuel and movies.
Neither icon is there and XM says it's GMC fault and GMC says its XM's fault.
Has anyone else had this problem and possible solution?
Hello sumoorr,
I understand that you are frustrated with your current situation with your vehicle and MyLink. I cannot guarantee anything but I would be happy to look into this concern for you. Please private message me with your full name and VIN.
Jennifer T.
GM Customer Care
  • 5 weeks later...
I cannot find the icons for fuel or movies either, just the weather.. and I want access to them
how do I add them?
xm says see GM and your mylink chat rep says call Xm,,,
how do I add the icons
Hello sumoorr,
Jennifer T.
GM Customer Care
Hi nomadicdogg,
Please feel free to send us your full name and VIN via private message as well. We will be glad to look further into your concern. We look forward to hearing from you soon!
Kristen A.
GM Customer Care
