Popping noise
Can anyone help I got a 13 1500 4x4 and if you shack the truck in the back there's a popping sound coming from the rear wheels also does it when u drive over something please help thanks
Sent from my DROID RAZR HD using Tapatalk
Quick checks I'd make, shock mounts (top & bottom), lug nuts (both sides), U-bolts on axle (both sides), spare tire carrier loose. To get a better idea of where it's coming from I'd get up underneath and have someone else shake the truck.
Semi floating axles produce noise when you shake the truck side to side. The axles are held in by c-clips at the carrier and there is naturally some play in the system.
I've checked everything to make sure it is tight guess its gonna go to the shop
    blueskytruc
    blueskytruc
  • Who's Online   2 Members, 0 Anonymous, 557 Guests (See full list)
