Windshield wiper removal
How do you remove windshield wiper arms on a 2006 silverado? I need to remove the plastic cowling cover and to do that wipers need to come off first. Is there anything special about removing the plastic cowling udner the wipers?
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,065 Guests (See full list)
