I'll be buying my gas elsewhere
bassdog
The Saudis are boycotting American goods. We should return the favor.
An interesting thought is to boycott their gas.  Every time you fill up the
car, you can avoid putting more money into the coffers of Saudi Arabia.
Just buy from gas companies that don't import their oil from the Saudis.
Nothing is more frustrating than the feeling that every time I fill-up
the tank, I am sending my money to people who are trying to kill me, my
family,and my friends.  I thought it might be interesting for you to know
which
oil companies are the best to buy gas from and which major companies import
Middle Eastern oil (for the period 9/1/00 - 8/31/01):
      Shell........................ 205,742,000 barrels
      Chevron/Texaco........ 144,332,000 barrels
      Exxon /Mobil............ 130,082,000 barrels
      Marathon/Speedway.. 117,740,000 barrels
      BP/Amoco..................   62,231,000 barrels
If you do the math at $30/barrel, these imports amount to over $18
BILLION!
Here are some large companies that do not import Middle Eastern oil:
      Citgo.................... 0 barrels
      Sunoco................ 0 barrels
      Conoco................ 0 barrels
      Sinclair................ 0 barrels
      Phillips........... 0 barrels
      Hess................... 0 barrels
All of this information is available from the Department of Energy and
each is required to state where they get their oil and how much they are
importing.  They report on a monthly basis.
Keep this list in your car; share it with friends.
Stop paying for  terrorism.............
But to have an impact, we need to reach literally millions of gas
buyers.
Please send this to 10 people.  How long will that take?  If each of us
sends this e-mail out to ten more people within one day 300 MILLION
people could conceivably be contacted within the next eight days!
This chain letter is all over the internet and the general opinion is that it is much outdated and some say it is just plain BS.  If you want to do something really useful, kick your Congressman in the a$$ to promote E85 or some other alternative to foreign oil.
BTW, by the time the fuel gets to the 'tank farm' or whatever they call it, no one knows where it came from.
First time I've seen this email, sorry if it's already been posted.
I do remember seeing your reply before, do you have it memorized or just copy and paste?  :cheers:
Sorry if I bent your sword....I was a little out of sorts this morning.  My old maid neighbor told me I was going to H3ll because I won't forward any of her religious chain letters.
