95 GMC Starter Solenoid Voltage
1995 GMC Jimmy SLT 4WD
What could be the cause of low starter solenoid voltage / current ?
Starter often only wants to click sound with no crank.
Whille starting engine my solenoid voltage measures 8.64 v, 2nd time measured 8.42v.
Ignition wire harness has been replaced .
Suggestions . . / . . . appreciated.
thanks for replies. Everybit helps .
I have done continuity to / from battery to starter and starter case -- 0 ohms on diode scale.
I have done voltage drop test across positive wire battery to starter -- 2.47 volts. Is the 2.47 volts while cranking turning engine over reasonable in this ~ 2- 1/2 footlong positive cable ?
Yes - I have read with age the ignition key switch contacts grow in resistance . . .
I remember maybe ?? ckeaning these when I put in the new ignition wire harness . Maybe.
I think I'll re-vist ignition switch . . .
2.47 volt is high. It should be .5 volts or less. If you have a jumper cable run it from the battery positive post to the starter. Then do the test again and see what your voltage drop is. Also have you done a voltage drop test on the negative cable?
Sorry, that was actually 0.247 volts; not 2.47 volts !
I'm going to trace the solenoid voltage problem later today.
If I remember the starter would turn engine everytime first time using my Remote Start cable/trigger ! Trying to get back on this.
I have just found that resistance from Yellow ignition switch wire just beyond ignition switch to the Starter Solenoid terminal is 0.6 to 1.1 ohms. What I see is that park/neutral switch is in this path. I want to find the Park/Neutral switch ??? It is not at bottom of steering column as one manual states.
Where is it ?
Checked Neutral Safety Switch - measures 0 ohms across switch - per Haynes manual - OK.
Continuity check wires from Ignition to Neutral switch to Solenoid - 0 ohms -- OK.
What is known as "hot wiring a vehicle" ?
Now I am jumpering RED +12 v Hot wire to YELLOW Solenoid wire both in Ignition wiring harness to Start my SUV.
Starting just about first time eveytime. Much better !
    • Can someone tell me where the video processing module is in a 2023 Silverado? I'm getting conflicting results that it's in the front passenger area or the rear passenger area behind the seat.
    • Yes I agree, its what amounts to free advertising to let people know about his UOA testing company, and not that there is anything wrong with that but certainly that is a motivator for putting out videos about the science of oil as well as other topics such as oil and air filtration etc. The interesting part I found with his last video is not only the physics behind the reason for the varying wear due to a diesels working torque range causing more bearing load and that higher viscosity oil is of benefit, it was also that the chemistry behind the GM Dexos 0W-20 and the Mobil Dexos licensed 0W-20 are far enough apart that its showing up with a difference in wear even though the two oils are matched in viscosity and in that comparison viscosity was not having the finger pointed at it.    There are a few youtubers out there or one anyway that I have watched a bit of who has gone through the pains of accessing various countries manuals for a certain engine platform and while in the US/Canada it may say use 0W-20 or what have you for some Toyota product, in some other countries it sings a very different tune for the very same engine with the typical traditional oil viscosity/ambient temperature charts to help choose which oil viscosity is correct for the conditions the vehicle will be used in and in some cases its taken an engine in a US manual that states only use 0W-20 as per warranty coverage and yet that same engine in certain other countries may have up to a 15W-40 etc oil option that meets the spec. Another words the guy who is driving through Death Valley or Phoenix and south weather at 120f is often being fed a line of bs by the US system that has forced vehicle companies to restrict the warranty to a specific low viscosity oil for anterior reasons as well as the long drain interval suggestions.    Thankfully youtube is free ( yet anyway ) for viewers to sift through information and of course comes with the good and the bad ( truth and lies ) and we can choose to turn off/not watch what a person finds is bs or just not interested in the topic.
    • No doubt... But, as someone who doesn't pay for his services, but who has provided a few views/clicks on his Youtube platform, the data around the Mobil oil testing I think does have some value including to "freeloaders" like me.   A lot of what he's doing is likely showing the OE's work in their oil selection, something that many of us had kind of assumed was true all along, a good balance of both excellent protection and efficiency.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
