Running boards
I recently purchased a lightly used 14 gmc z71 slt off eBay. It looks and feels brand new. Question: how much do running boards help in keeping your seats from getting really worn. My previous truck had them and when I exit my new truck I feel like I could wear my seat out really fast by sliding in and out without steps. Thanks in advance for any thoughts on this.
In addition the drivers assist handle like the one on the passenger side is helpfill setting you in the seat instead of sliding.
I had the 6" chrome steps installed as part of my purchase. I drove the truck a few days before having them installed and I had the same thoughts...sliding off the drivers seat over and over would certainly cause long-term damage. With the 6" steps it's an easy in and out, I don't even grab the steering wheel.
