FS: 2003 GMC Yukon XL 2500 3/4 Ton 4x4 w/Quadrasteer, 213K, in MI
Up for sale is my 2003 GMC Yukon XL SLT 2500 (3/4 ton) 4WD with ultra rare Quadrasteer option. According to GM, only 466 Yukon XL's left the factory with Quadrasteer in 2003, so this is truly a rare truck. You will not find another one like it any time soon. This truck has EVERY OPTION except for a rear DVD player and a sunroof. I am confident that you will not find a truck as nice as mine out there, even if you find one with lower miles.
ASKING PRICE: $8,000 or best reasonable offer, below KBB "Good" Value for this truck with this mileage.
Want to chat more about it? I can be reached during normal hours (please don't call after 11:00PM EST) at 24eight-nine8seven-8sixzero5. Also available by PM on the forum.
**Full GM build sheet available upon request**
**Carfax available upon request**
**Autocheck score of 82; report available upon request**
More than 70 full photos of the truck are available for viewing in this public photobucket album. Here is the link to it.
A word on Quadrasteer if you are not familiar: The rear wheels turn along with the front wheels, giving this giant truck the turning radius of a Honda Civic. Once you drive it, you'll wonder why every truck does not come equipped with this option! The Quadrasteer system works as it should with no "Service 4 Wheel Steer" or other error messages or codes.
Reason for sale:
I have too many vehicles and this one gets driven the least, so it has to go.
Ownership history:
I purchased from a dealer which bought from another dealer, which got it as a trade in from the first owner. I am the second individual owner. The truck has a clear and clean Michigan title. Before that, it was in Ohio. My mechanic remarked that it looks like a Southern truck underneath.
Key Specs:
Mileage: 213XXXK (low engine hours - only 3800) - mostly highway miles. Vehicle is still being driven, so mileage may still go up a little bit.
6.0L Vortec Gas Engine
3.73 Rear Axle w/Limited Slip Differential (rare combination)
Heavy Duty Automatic Transmission -- shifts strong
Push-button quad-mode 4WD system with Auto, 2HI, 4HI and 4LO
Pewter metallic exterior (GM code 11/WA382E)/Gray leather interior (GM code 922)
Comfort:
Always a non-smoker truck -- no odors whatsoever
Brand new (January 2014) Weathertech floor mats, not pictured but included in sale
Dual zone automatic climate control, plus rear A/C and heat control
Ice cold A/C (new compressor 5/2014 and full R134a charge) and hot heat
Full leather seating, new leather seat bottom for driver's seat May 2014
8 passenger seating (2/3/3) with removable rear leather bench seat
Onstar (subscription required)
Bose Premium Stereo w/XM
Heated and power front seats
Running Boards
Roof rack
Other Equipment:
Heavy Duty Tow package (includes Class IV receiver, towing capacity 7600lbs)
Hidden Hitch electronic trailer brake controller
Rear A/C and rear media controls
Z55 suspension package
Polished aluminum wheels with minimal peeling/curb rash
Roof mounted front and rear clearance lights and fender courtesy lamps
Recent maintenance:
-New right side exhaust manifold and gasket -- December 2013
-New Cooper Discoverer H/T Tires Load Range E tires (OEM size 245/75/16) -- December 2013 (about 3,000 miles on them now)
-Oil changed with Mobil 1 Synthetic -- December 2013
-2 New OEM GM remote key fobs -- December 2013
-New rear lower quarter panel (replaced due to rust) -- December 2013
-New battery -- January 2014
-New rear hatch glass struts -- January 2014
-New rear wiper motor -- January 2014
-New wiper blades (front and rear) -- January 2014
-New power steering pump -- April 2014
-New rear washer pump -- April 2014
-New washer fluid tank -- April 2014
-New power steering gearbox -- May 2014
-New Denso A/C compressor and A/C system fully charged -- May 2014
-New heated seat pad for Driver's Seat -- May 2014
-New driver's seat bottom leather -- May 2014
-New outer rear outer tie rods and RR outer tie rod bracket -- June 2014
-4 Wheel alignment -- June 2014
-Replaced roof mounted convenience lamps with used OEM units - June 2014 (not pictured)
What else you might want to know:
-There are NO Check Engine Lights or other warnings.
-There is a slight clunk perceptible when accelerating from a stop. It's been like this as long as I've owned the truck. It only does this about 50% of the time. I've had two shops examine this issue, both have told me everything is tight in the front end as well as in the driveshaft.
-The driver's side heated seat turns on by itself sometimes, but usually will cycle off. Sometimes it won't act up for weeks at a time. I will include a brand new heated back pad for the heated seat as I suspect that if there is a short, it is in that component, and because the heated pad on the bottom is new.
-There is some surface rust on the lower door sills, especially on the driver's side. See photos.
-The power retracting tow mirror only extends and retracts on the passenger side; the driver's side does not retract or extend (but otherwise works including power adjustments and heat).
-There are a few stone chips in the paint and a couple of small door dings.
-The CD player/changer does not work (although the previous owner's Rihanna CD does play, it will not eject or accept new discs)
-The optional power steering fluid cooler was leaking, so the system was routed around the cooler. Because this was an option only, the truck runs fine without a cooler.
-There is a sealed stone chip in the far corner of the windshield.
-The rear washer does not work, even though the pump is brand new. There is probably a leak somewhere in the line. I did fine just using the wiper.
I'm not looking to waste your time or mine so I am fully disclosing everything, both good and bad, that I know about the truck in this ad. Please keep in mind that you are purchasing a truck with 213,000 miles on it so there might be other issues, and you purchase the truck AS IS. I am not making any warranties or representations about the truck or its fitness for any particular purpose.
I also have the following spare parts which can be sold with the truck at an additional cost for the buyer, but are not currently installed on the truck and will not otherwise be included:
-Extra pair of OEM GM power extending tow mirrors -- not as nice cosmetically as what is on the truck now, but they are believed to be working, rare and very expensive
-Garvin Industries Off-Road roof rack with lights
-Chevy Suburban Z71 off-road roof rack
-GMC Yukon Denali front grille (billet style)
-Extra Quadrasteer ECM Module (given the rarity of the parts, I wanted to have a spare in case the one on the truck went bad. It didn't, so I still have this part).
-GM 7-Pin to 4-Pin Trailer light adapter
-OEM GMC Yukon Denali/GMT800 touch screen navigation head unit with GPS antenna and 2013 GM Maps disc (plug and play installation)
-Scosche BFCL2K Bluetooth Hands-Free Kit with Caller ID (new in box)
Logistics:
If you want to take a test drive, you must have a valid driver's license, no exceptions.
If you want to have the truck inspected, I will make reasonable accommodations to have that completed. Any inspection will be performed at the buyer's expense. Any inspection must take place prior to sale.
If you want to have the truck shipped, I will work with the buyer or buyer's shipping agent to arrange that. Please be aware that I am not responsible for any damage sustained during transit.
If you want to pick the truck up, it is located about 30 miles north of Detroit Metro (DTW) airport. I am willing to pick up a buyer at the airport.
Buyer is responsible for sales tax and license fees in buyer's state of residence.
DSC00669_zpsdfd8b8e0.jpght
    LeeBob
    LeeBob
  • Who's Online   3 Members, 0 Anonymous, 998 Guests (See full list)
