I'm having an issue I can't resolve with my Tahoe. It's a 95, 4x4, 2dr, 5.7, with a 5 speed manual in it. It wants to miss on acceleration and pop a lttle through the exhaust. It doesn't matter if its cold or up to temp. When it first started, about 3 weeks ago, it was only in 3rd gear under medium acceleration. Then it started in 5th gear under a load, like pulling a hill. Now it's in every gear but 1st.
I have replaced, since the issue plagued me,
TPS & connector
MAP
EGR
CTS
Distributor
I have replaced the fuel pump since I've owned it (little over 3 years). The tune up is less than a year old. Knock sensor is less than 2 years old. IAC is maybe 3 years old. All with Delco/Delphi parts with the exception of the distributor. It's NAPA, Cardone I think.
I replaced the distributor because the trigger wheel(reluctor?) had a pretty good crack in it. So last night after replacing, setting time, and clearing the code, I drove it about 20 miles with no problem. Get in it this morning and pull out on the road, get to 2nd and feel a tremble, go to 3rd and it bucks and misses. I feather it out, hit 4th, bucks and misses.
Disconnecting the battery is the only thing that makes it go away, temporarily. On the next startup, it's back to bucking. Any fresh ideas would be appreciated.
No takers?
I drove it yesterday afternoon, a good 40 miles of stop and go on backroads. Eventually the problem went away. By the time I got close to home I couldn't make it miss. Get in it this morning and it misses like hell. I put about 30 mile on it this morning and the problem fades away. O2 sensor not heating up maybe?
The code was form disconnecting the timing wire. Which also answers lee123's question, I set the timing with a light.
I pulled the plugs Thursday afternoon to find they were all frosty white(bad lean). I brushed them off, checked gaps, put them back in, and disconnected the battery to clear the CTS code. It set the CTS code because I wanted to see if being unplugged made a difference in anything. It idled a little higher, which I expected, but didn't resolve the main problem. I only drove it a couple of miles with the CTS unplugged, I squirted a little WD-40 on the grounds by the water neck and took of on a test drive. It never acted up for the 40 or so miles of starting and stopping I did on the backroads, and I didn't expect it to.
I jumped in it Friday morning and expected the miss and nothing happened. Drove out like a champ. And it's been good since. So either the plugs were that big of a problem, which I doubt, the issue finally reset with a battery disconnect, or the grounds needed WD-40. I found someone with a live-data scanner that won't rape me like the dealer would if I went to them. When the issue hits again I'll be ready.
The miss came back about 10 days later. It started small, occasionally in third, then worse and worse by the day. Always bad on first start of the day and getting better the longer it ran. It acted up until the scanner was hooked on it. Then it didn't miss a beat. It was a nice SnapOn scanner, but it couldn't tell us anything usefull. Only whether or not it was in open or closed loop, the temp, rpm's, and lean/rich from the 02 sensor. No live data, like TPS % or IAC and O2 counts.
So I think I'm gonna throw another 20 bucks at it and put an oxygen sensor on it. If that doesn't do it, I'll start replacing connectors.
Yep. I've waved an unlit torch around about everywhere I can think of.
This things got me. I went home for lunch, spit and sputtered. Came back to work, it didn't miss a beat at first. I slowed to make a turn, had to downshift to 2nd, accelarated with no miss, shifted to 3rd, hit the gas and wham, big miss. Then nothing the rest of the way. And it doesn't seem like it's wanting to settle into it's idle. Like it's a fuzz higher than usual. Got a different tone to it or something. Just doesn't seem right.
My truck had somewhat similar issues when my dad had it. I am not very knowledgable but after a new ground wire was installed it fixed the issues.
I had the distributor cap off of it Tuesday afternoon and noticed the center terminal, coil terminal, was loose. I put a cap on it yesterday and fixed the problem. That was the third time I've had the cap off since this issue started. I touched the terminal just right to feel it wiggle.
Thought I would post back because I've seen so many topics on forums all over yet nobody ever posted the fix. But my fix may not be someone else's.
I know this is an old thread but thanks for posting the fix, I'll definitely remember it if and when needed.
  • 3 years later...
  • 10 months later...
On 7/17/2014 at 9:05 AM, jham0077 said:
I am having almost identical problem in my 1997 GMC Sierra C1500 4X4.
No takers?
No takers?
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
