Help! No Low Beams on 09 Tahoe!
Hi guys, I tried posting this on the tahoe yukon forum where i usually lurk :P , but got no responses.
This is for my 2009 Tahoe
Both low beam headlights quit working today... they don't work with the light selector switch in auto or low beam mode. The DRLs and high beams come on fine.
Interestingly, when I turn the light selector switch to high beam, the low beam bulbs light up fine along with the high beams... so the bulbs are fine.
I tried changing the relay labeled "HDLP LO/HID"...didn't help, and checked both 20amp low beam fuses (#11 & 16)... they're both fine
Anyone have ideas on a fix for this?
As far as I know the hi and lo beams don't work at the same time. If your hi lo switch gives you nothing or both I would think that is the defective part.
Im pretty sure the low beams come on with high beams on 07+ trucks
My guess is the multi function switch. I have an 04 Impala that lost hi beams, (they would just go out at random times) then lost both hi & low beams. New switch on the steering column fixed it.
Yes they do
+1
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 909 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
