Abs brake light
Check brake fluid level. After that scan it with a scanner capable of pulling codes from the EBCM
As suggested scan with tool capable of ABS code reading.
If you don't have a scanner or access to one check all the wheel ABS sensor wires. I have had front ones (wires) break on several vehicles.
