As the title says, for those of you doing mods, how have you routed any new wiring through your Sierra/GMC's firewall?
I apologize if this has been covered somewhere and I have missed it in my searching. I am contemplating doing a number of mods to my Sierra which would require running wires into the cab for switching. I'd love to be able to do this relatively cleanly. Any thoughts about:
1) Pre-existing unused firewall ports.
2) Pulling wires through the door frame. One mine there seems to be a unused hole covered by a plastic/plug?
3) Running up through the floor somewhere?
4) Coming in through the back of the cab. While haven't checked I do remember reading somewhere that a guy had run control wires for his flashers through the cab vents at the back of his older model crew cab.
Thanks in advance.
I ran the wires for my driving lights through the existing hole where the steering shaft is. There is a flexible rubber piece around it that you can bend back and place wires through.
The Emergency brake cable is another good one to follow for a few small wires, that's how I did my FD emergency light.
Thanks for the responses. Sorry I got a bit busy with the kids over the holiday and hadn't had a chance to reply until now. I know plenty of people have run through the steering wheel boot, I'm just a little hesitant about doing so at the moment.
Resqu2 - I like the idea of going alongside the e-brake cable what gauge wire did you use and how many runs do you have going through that area?
I am going to give a shot at trying to find the mythical accessory harness grommet the upfitters manual recommends for running snowplow wiring: Electrical Manual pg 75 and 76.
I would assume that even though my truck is a crew cab the plug should still be there.
  • 5 years later...
Help!  I need to run two #4 wires through the firewall on our 2015 GMC Yukon to run a 1500 watt power inverter mounted under the front seat about 12' of wire.  This will power a ventilator and oxygen concentrator for my wife on trips to the doctors offices, she has ALS.  This has to be a first class installation, we can't have the power go down or a short. I  have a Bussman 90 Amp circuit breaker that needs to be mounted in the engine compartment probably on the upper firewall.  I plan on getting power from the spare lug on the fuse block on top of the battery.  The first two feet of wire probably won't be fused or breaker protected as I didn't see any fuse sin this block?  Is there any way to protect this wire in the block?
Any help or guidance anyone can provide will be greatly appreciated.
Thanks, Jack
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
