04 gmc sierra 2500hd c0110 abs code
04sierra2500hd
i recently had the abs light come on. the one front bearing had a decent amount of play in it. so i replace that hub/bearing/sensor, thinking thats the problem. brought to a shop to have the code cleared. turns out it has a c0110 Pump Circuit Malfunction code. i was able to split the module from the pump. i ohmed the 2 prongs for the pump motor and got 0.0 ohms. so i would say the pump is good. i opened up the module hoping to find a bad solder on the board, but didnt find any burnt spots. so i sealed it and put it back on. when i plug it in it makes a buzz noise for a split second then stops. i tried cleaning the ground on the frame rail but that didnt work. any help would be greatly appriciated.
  • 3 months later...
there is extremely limited info out there for this code. after more diag i found that the pump is bad. it ohmed out correctly but the motor wont turn. i just wanted to update this incase anyone else is ever in this situation.
Ya have to BUY service information from alldata.com for $27/yr , then ya can follow codes properly instead of BS Internet crap , ya don't have to struggle is my point here ,
It's not hard people...
