Going over Gross weight on 1500
Hey guys, need some advice from the pros here. I'm trying to make something work, SAFELY!. I have a 2002 GMC sierra 1500 4x4, extended cab with a 5.3l engine. I acquired some time ago a truck camper weighing about 1575lb which is built to sit on the bed of the truck. Normal Payload I calculated I could put on this truck is about 1600lb. But with myself and other stuff on board, i'm probably adding an extra 450-550lb max. I acquired some heavy duty helper springs which make the springs work beautifully, and tires capable of handling much more than I need. The setup is comfortable, truck pulls hard and stops well.
I've been running the setup for 2 months around a few trips, love it, like having a decent size camper with much more decent fuel economy than anyone can get. About 16-17mpg I'm soon planning on going on really long work related trips where this setup will serve me greatly.
As comfortable as the setup is, I am going over gross weight by an estimated 400-500lb. I don't want to upgrade to a 2500 series since the only engines available are horrendous of fuel. The truck is built to pull a hell of a lot more, so drivetrain and braking are not a prob and have zero struggle. The springs and tires are upgraded and work perfectly. But what worries me are the frame and Axle. Is the frame on a 1500 series built significantly weaker than a 2500 or is my frame not going to be a weak link in this setup? Although the whole truck's gross weight is over, the gross weight than can be handled on the axles seem to be within Gross weight range, but barely on the rear axle . Any stronger rear axles I can upgrade to while keeping the same drive ratio?
Am thinking that with what you have done to beef up the suspension and tires will more than exceed that 500lbs that you feel you are over. Go out and have some fun! IMO
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
