Anybody have this issue?
It seems my Y pipe where it bolts to the mid pipe is hitting the heat shield and I'm getting noises over bumps I tightened the studs and it's still loose so I hammered them out and used bolts, but still I can push it up to the floor board, I wedged a piece of aluminum in there and it went away but it's rattling the cab now I checked all my manifold bolts, I am wandering if the cab mounts are weak? Any ideas?
An "L" styled bracket I picked up from the local exhaust shop. Slapped it on at the base of the y. I originally had a hose clamp but it was only temporary until I put a little spot weld on it.
I've also seen guys run a piece of steel or aluminum straight across underneath the y pipe if you feel comfortable resting right against the heat shield.
