intermittent gauges draw
FFTM
I have a 2500 HD with a 6.0. I have a draw on the battery at times. I pulled the IPC/DIC fuse and the draw goes down to normal. Can this be fixed by having the cluster rebuilt?
Bit of a stupid question, but, are you trying to fix a problem or did you stumble on this and think it is something that needs to be addressed?
My battery has been intermitently going dead for the last few years. At first I thought it was an old battery so I replaced the battery. I had no trouble till a few weeks ago. It went dead out of nowhere. I had it at home and when I disconnected the battery I come hear motors shutting off. I had my wife listen and she said it was in the instrument cluster. So I got my amp meter and I had two plus amp draw. Well I went to the internet and read mostly about cluster itermitent draws. So I went back pulled the IPC/DIC fuse draw went to mabe half an amp. But now the system is working again with no parasitic draw. I am tempted to send it out for repair but at the same time don't know if the would find anything to fix. So I found this site and joined and I am trying to get more input.
When you were testing the draw, how long were you testing for? I would suggest you leave it connected for 30 minutes and watch how the draw changes during that time.
Whenever you connect the battery up, it will have a certain amount of current flow to energize whatever the PCM/BCM wants. This should not last very long though.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,440 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
