Smells Like Burning Tranny Fluid
Well I have a 2014 Silverado 1500 5.3 with just now 5k miles on it, recently on the parkway the other night while under heavy acceleration to get on it started to smell like burning tranny fluid, I flipped right to the temp gauge screen and it showed 196 which is smack on normal for my truck. It quickly went away so I dismissed it, but it happened again the other night while driving through some mud, in 4wheel drive, tranny was only at about 2,500 revs to keep the truck moving tranny temp again at about 201 normal in 4wd for my truck burning tranny fluid smell
I'm making an appointment with chevy on Monday morning but does anyone else have any experience in this
You better get under your truck and check where the tranny lines connect to the trans. There is a TSB regarding that some where not popped in entirely or correctly and leak causing fires on some. It is at the connection to the trans.
ASAP!
Ohhh boy, figured this issue would of been resolved as I brought the truck well after the TSB, I'll climb under her tomorrow before work, thanks
Dealers are idiots. I bought mine a couple of months ago, after the publicity and TSB and happened to mention it as we were picking up our truck. I had my kids with me. They look at my request…after telling me its was done…..yep it was not done! I made them take it over to the service shop and complete the check with written confirmation it was done. Idiots!
Yes they are, I just called my dealer and explained the issue "we are currently setting up appointments for the week of the 13th" gunna make me wait 3 weeks to see if my truck catches on fire? yeahhh no
Is there a chance that it was from another vehicle? I had this occur to me a couple weeks ago. Only once and I was under the truck after that measuring up for my exhaust with no signs of a leak. I've also put on 2500 km since then and it hasn't returned so I'm assuming that it may not have even been the truck.
That's what replacement insurance is for.
    Mistycool
    Mistycool
  • Who's Online   2 Members, 0 Anonymous, 1,937 Guests (See full list)
    • I am having similar issues.. 08, 4.8L granted I did had a fender bender and minor damage up front passenger side but I don’t think it had anything to do with it.. I had the high and low pressure checked and my fan for my radiator keeps coming on.. replaced the pressure switch and don’t want to keep throwing parts at it. I did have some minor problems here and there like on long road trips sometimes the ac would get a little warm and then on the highway as soon as I give it a little gas or get a little heavier on the petal it started running cooler. Never had an issue with the ac besides the here and there.. but I also started having issues when I fuel up now it takes a bit to start ( super embarrassing) it runs fine and once started ( only happens after fueling up) starts fine any other time. Could they be related?
    • Spent a small fortune on fuel this weekend.   $6.69 diesel, 18 gallons of that. $6.99 92-octane ethanol free, 10 gallons of that for yard machines $5.59 87-octane for one of the cars, 11 gallons.   $250+ and I didn't even get a tug.   Hormuz ain't Hormuzin again, did not see that coming...LOL
    • Appreciate the advice. I've watched multiple videos. Most showing the most complex for those that have a center console, to one that showed maybe 2 pieces of trim being removed, like 6 screws, pulling back the screen and switch assembly, and installing the inline module. And this was a new/newer Silverado. That didn't look too bad. All the others show alot of trim pieces that need to be removed. I've broken those kind of tabs/clips on my C8 Corvette trying to get to the battery, and that was a lot less clips than what I think is involved here after watching multiple videos and looking at my dash today. I have one on the way. Called a reputable stereo place about installing it and got a "minimum" price of $175. Ouch! Looking forward to seeing what the instructions have to say.
    • Hard to say what the issue might be. Anything from the ability to cool the AC condenser up front, to blend door issues in the HVAC unit, to refrigerant charge, to compressor issues or issues in the lines.   Report back what the techs find on the 29th.   GM has service publications which list acceptable vent temperatures and AC pressures at given ambient temps and humidity. They probably won't touch the system if it's operating within those ranges.   I'm also surprised to hear your 2024 with the L8T is still using R134a? I was pretty sure the HD's had switched to the new refrigerant around 2020.
