Wierd - snow and thunder?
RyanbabZ71
Ok today something wierd happened.  It was raining then it turned to snow.  Well it was snowing for about 30 min and it was also thundering  :crackup:  :crackup:
Has anyone ever heard of it?
I guess the saying (chicago) if you dont like the weather wait 5 min was true today.  It was 40 while going to work.  Then it rained temps dropped it sleeted then snowed.  Now it is 15 degrees and icy as heck
Sounds like the weather here. (OK)
It was 75 earlier, now its about 30. Wind at 20 mph.
I have heard thunder during snow. Not often, but I have heard it. It is weird.
When I lived in Erie PA we would have that happen a couple times every winter.  The cold front would sweep across the lake and hit the warm air, and then thunder and snow...
It has happened here in WV some.
Yeah I've seen/heard that too now and then.  A few years back I during a snow squall I even saw some lightning flashes.
One of the weirdest things to see is a hailstorm on a hot summer evening when the temperature has been high all day.  Last July it had been 96* to 98* all day and then around 7pm it got real black & started raining hard.  A few minutes later nickel-sized balls of ice started falling and it got cold.  Looked at the thermometer and the temp had dropped down to 65* in less than a 1/2 hour! :crackup: Weird.   :crackup:
ever heard that stnad up Lewis Black did
"There was snow, rain, sleet thunder adn lightning TOGETHER!!! That kind of stuff didn't even happen in the BIBLE!!! And if it did, you think they would have enough decency to tell us about it after they wiped the poop out of their pants!!!"
One of the weirdest things to see is a hailstorm on a hot summer evening when the temperature has been high all day.  Last July it had been 96* to 98* all day and then around 7pm it got real black & started raining hard.  A few minutes later nickel-sized balls of ice started falling and it got cold.  Looked at the thermometer and the temp had dropped down to 65* in less than a 1/2 hour! :nono: Weird.   :)
That happens all spring long here.
Nothing like watching that big a$$ wall cloud rolling in.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
