Should I go with another 2014 or wait for a 2015 Sierra?
BluByU14 well mine is having the the same problem as your 2014 I'm worried now knowing you are getting a new truck now. Not that I would mind having a new 2015 if they can't fix my vibration problem. I'm taking it in Tuesday for the second time for what I hope they find the problem and a fix.
My truck is a:
2014 Denali 4WD 6.2L
I ordered it mid April picked it up at the dealer on 28 May.
My truck is a:
Sorry to hear that you are experiencing the same issues that I have had, as well as issues that a lot of members here have had too. My best advice it to remain calm, positive, and firm with the dealer. I simply told that the dealer that I wanted a truck that was "vibration free". If they could give that to me by fixing my 2014 or by getting a me a replacement, I would be happy. I spent nearly 3 months going back and forth to the dealer before they offered to buy my truck back and order me a 2015. From the onset I did let the dealer know that this was a well known issue with these 2014's. They seemed to play it off, but I was persistent in telling them that the vibration/shakes with these trucks are more common than they believe. I referenced some of the stories/cases that have been described here on this forum. They then knew that I wasn't going to just "go away".
I hope you dealer is an advocate for you through this process and can make things right for you.
Please keep us posted with what happens!
Best of luck.
I can't believe with the hundreds maybe thousands of truck exhibiting these symptoms that GM can't find a fix and is still buying back trucks at huge losses. Has anyone ever gotten one fixed yet and I mean anyone own one, not heard of one that a friend of a friends brothernlaws sisters husband had one fixed?
Best of luck.
Well I was suppose to take it in Tuesday but they called me Monday and told me to bring it in on Friday so I'm taking it in the morning there suppose to be a engineer there to check my truck out also. I will keep you updated on how it it goes.
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
