Snap on Grille
Bonker
  • Replies 34
post-46848-0-60544700-1419794258_thumb.jpgHere is mine she is really dirty and needs a good wash
  • 3 months later...
I put a chrome snap on grille a little less than two years ago and had no issues with it. It is hold up great and I feel it looks great. If I get tired of it I can always go back to the original black grille. Cheap and easy accessory to install.
    Dom Colussi
    Dom Colussi
  • Who's Online   3 Members, 0 Anonymous, 551 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
