DI engines and oil catch cans
When talking to RX about a catch can, we got on the subject of DI motors and the intake valve/guides coating issues. Big issue on Vett boards. Some have torn down engines at 6000 miles.
RX strongly recommended a CC for the new DIs to try and keep the junk off the intake valves. Just saying.
Yep we've been discussing this topic here: http://www.gm-trucks.com/forums/topic/154204-oil-catch-can/
I still need to get one of these things. According to my side mechanic though they won't stop everything and you'll still need to clean the motor about once a year to keep it running in tip top shape. Google BG Induction Service to read more about this work that is starting to become routine maintenance on DI motors.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
