new nerf bars
hawks13
:nono: I just bought nerf bars and put them on my truck.  I just had a quick question to people who put after market nerf bars on their truck.  After installing them did your truck ride or drive differently or is it just a psychological factor to me?
I thought I was the only one who noticed that my truck rode diffrently after nurf bars installed.  It seems to be more solid or ridged as far as the frame of the truck feels.  The ride seems the same but you do notice a stiffer feel.
Hope I'm not losing it I'm too young.
:devil:
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
