ABS/Brake light Service Brake system Error Message
LouieC
:chevrolet: Ok I could really use some help with this one ....I am getting the error message brake system needs service I hooked up my Tech 2 and got the code for a mismatched wheel speed checked the "speed vs. Spedo and I start out at 3 mph not moving at low speed the abs sensors and spedo are within 1-2 mph the front to rear is also within 1-3 mph at a little higher speed I am almost a full 10 mph difference front to rear but the rear is dead on with the spedo I have the same size tires on the front and rear 275-65-20s I am just having a problem thinking that BOTH front speed sensors have gone bad at the same exact time.... Cant figure what I am missing
2004 Silverado LT 5.3 "T" 2wd
You have to follow the code and not assume anything is "bad" I use "failed" but whatever floats your boat
No guessing is my point ,
Have you verified air pressures in all 4 tires with the same gauge? Keep in mind that the speed difference is actually in a percentage. 3mph out at 30mph is the same as 6mph at 60mph. If it is showing any speed when not moving, that should be pointing you at the issue.
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 897 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
