chrome question
My wife hit my truck last night with her van and scratched the hell out of the front bumper. Spiderwebbed the black paint on the drivers side corner of the bumper. Dented her brand new Honda Odyssey with 300 miles on it pretty good. My question is is the chrome on these trucks clear coated? If not I'll use some noxon 7 to try and get rid of the scratches in the chrome. Thanks
