Corvettes and their cams!
Ridinghigh
Ok fellas, here is the situation. My friend has an 85 Vette with the L-98. We are tearing the engine apart for his senior project and are rebuilding it. The engine so far seems to be in GREAT shape. We were talking to a knowledgeable guy at Baxters (our local parts place) and he hooked us up with an Edelbrock Performer Plus. It seems to be a fairly modest cam, however we want something with a bit of juice to it. The car is a daily driver, but we are lookin for some balls. The car is pretty fast already however we have a need for speed (dont worry we confine our racing to the track).
For all you smart people out there, what is the best cam for us to use in his L-98 that would give us some excellent bottom to mid range power but wouldn't totally destroy driveability.
Help appreciated . . . thanks fellas.
:D
Cams are not really my first choice of things to go after in chasing down performance.  You can really screw drivability up by just doing cam.  Unless you are doing other modifications to allow the engine to breathe much better, the Edelbrock performer plus that was put in was probably a good bet.  What kind of intake? Exhaust? Is the engine basically stock?
Well, i know Lingenfeilter makes a very nice cam for the L98, but is usually complemented by a super-ram intake from him as well. That starts to get into some $$.
With a new cam, new heads are also something that should be thought about.  :D
    flyclt
    flyclt
  • Who's Online   5 Members, 0 Anonymous, 592 Guests (See full list)
