How to? Stock radio repair.
So I'm working on a possible electrical issue in my truck and I think I may have found the problem. I think I may have a possible shorted stock radio in my truck. Does anyone know what exactly is "shorted" causing a battery drain? Also is it repairable or am I looking at getting a replacement radio? I know how to solder and do a good deal of repairing but I've never had the experience of tearing into one of these type radios. So any opinions and/or suggestions are welcome.
I've never heard of anyone repairing one. Mine randomly resets itself sometimes and if it ever gets bad I'll just get an aftermarket unit, they're far nicer.
It's never been a problem, this morning I noticed an increased amount of charging voltage. My "Service Air Bag" has been coming on since July and it seems to always cut out after the battery has been charged up. I pulled the fuse on the radio as a test to see what happens over the next few days....don't typically listen to the radio much anyway, just miss my clock is all.
Nope, noradio cut out. It works just fine. Just guessing it may be the problem. I have the truck scanned at auto parts place a few times & no codes for air bag. I think that's because of the scanner they have. Unfortunately I don't have $100 to have dealer scan it so I'm playing blind troubleshooting with a voltmeter.
Yeah the air bag light could be anything from a short to a sensor to the module, I'd get someone with the right scanner just because it could make it a lot easier to figure out.....
A plug could be disconnected under the seat. When my passenger seat was out the light was on
Maybe you can borrow a clamp on ammeter from someone and measure the parasitic (key off) draw on the battery to see if you have a problem and then start to track it down. Typical key off draw should be in the 30 mA (0.030 A) area. Do you keep anything else plugged in? Like a cell phone charger, mp3 player, etc?
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,315 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
