It is days like today
jerseyTahoe
OK.  Today is a lovely 65 degrees out and I am stuck inside all day.  Yea that stinks but it is no big deal.  I work full time in an office so I accept that.  But the fact that the building is a whopping 85 degrees inside.  :eek: I mean it is hotter than  :lol:  :nonod:  :D in here.  They haven't even opened the cold air fresh air vents.  I can't even concentrate.  It has been the longest day in a long long long time.  I can't wait to get out of here and have a few  :nonod:  with my buddy.  Then I am going to the driving range.  :thumb:   If I don''t get out of here soon I think I am going to lose it.  :jester:   Well I hope everyone else will be having a much better day than I have.  Sorry to vent but it had to be done. :lol:
Yeah I know what you mean, yesterday I got back to my dorm from Spring Break and I swear it must have been about 80 degrees in here!!! I was really pissed how am I supposed to sleep with it so freakin hot...I dang near sweated you-know-what off, now it feels about right, why can't they just leave it at 70 degrees all year ???
Tom
Well I've got it the other way..........
The minute the temperature goes above 70 they things it the middle of summer here and crank the AC to about 50.....
Enough to   freeze your buddies off..........
BUt today it's rainy and overcast so the temp is about right..
Then I guess you'd be pi$$ed if I told you I just spent the last 2 1/2 hours at a local seaside Hooters drinking beer with their doors open in 78 degree weather?  :owned:
Some guys just have to rub it in. I could go for an afternoon at Hooters myself. The one in Ocean City will open soon for the summer.  :thumb:
yZR2K.  Thanks for the good idea.  Last night after I got out of work, me and my friend went to the driving range and shagged some balls then went to Hooters right down the road.  $0.99 Killians Draft last night.  What a great deal.  Well last night as soon as I got out of the building the day got much better.  We will have to see what happens today.
Later,
Brandon
Sometimes Im glad to have an outside job . especialy when the days are sunny and 70 -80 degrees . But now my ears are still ringing from hearing those steel tracks for over 10 hrs a day  :devil:
The 1 I always hate is when it gets hot and I start sweating and it runs down the center of my back under my vest where I can't do anything about it.  You're standing at the window booking someone in and just feeling that slow drip and it running down the center of your back.
    Policeoff01
    Policeoff01
  • Who's Online   3 Members, 0 Anonymous, 823 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
