I haven't been around for some time and that's probably because the 2001 8.1L CCLB has been such a good truck. but with 106k it was time to get myself an upgrade. Found me an 2011 sierra 2500HD. Things have changed quite a bit in 10 years but I know I'm going to miss the power. I posted the truck in the for sale area. Let me know if anyone is interested.
Maybe not
360 HP 380 Torque
6 speed
4.10
Mine works mighty fine / so should yours
plus I average about 14 mpg combined (driving sane)
ENJOY !
I like the new truck quite a bit. Came with some led lights and wheels, sharp looking. It's the 455 ft-lbs of torque @3200 rpm that is the huge difference. I didn't pull much anyways. Mileage should be a nice perk since I only got about 9 (short trips) with the 8.1.
