Ecu swap
Teeroystoy
I currently have an 05 gmc 6.0 and I purchased a 04 6.0 motor with ecu.
I've read old posts how to and procedures to do the swap with key on key off steps and it has worked besides it doesn't function completly correct.
Throttle doesn't do anything when stepped on
Revs up
Knocking noise
And sounds like a huge cam has been installed
Does anyone have any tips on this issue without using dealership ?
Thanks for any imput
As long as bot 6.0's are the same motor, you dont need the ECU. This assuming they are HD's. The engines are identical. Kind of the same if you have a 1500. The difference between 04 and 05 in the 1500 is electric fans. Basically pull motor, drop in new one, plug in and do a ctank relearn.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,068 Guests (See full list)
