4x4 Trying to engage involuntary on GMC Sonoma 4.3
Shrubbie
My 4wd has been trying to engage on the highway, not enough to lock in, just enough for it to make a horrible grinding noise that forces me to the side of the road. Also at idle it makes a knocking sound similar to an engine knock but it's coming from the passenger side front wheel. Any clues to what it might be? I was thinking it was the actuator but what else could it be? Thanks.
I assume you have electric shift , it could a number of things but having the TCCM scanned is the first thing to do ,
Don't get into the shotgun parts at it thinking
I think the tccm is fine, it's just the actuator doesn't have the power to keep the 4wd unlocked, and it's slipping a bit. I could be wrong though.
It goes in to 4wd just fine, it's coming out that's hard.
The TCCM stores codes on the whole system ,so I think you misunderstood what I said ,
You need a schematic and base electrical diagnosing skills to fix this , but hey , throw a part at it anyways ,
  • 1 month later...
Update: took it to the dealership I work at, the 4wd Vacuum pressure switch was bad. They replaced it for 70$ and it works like a charm.
