2015 Silverado 1500 gears 3.42 wanted
Anybody take out those 3.42 gears I`ll buy em has to fit 12bolt 9.5 ring gear newer hybrid axle.Dont need carrier got G80 with 3.08
I'm not by any means trying to be $hity but from experience you would be better off buying a new ring and pinion set. I have been setting up ring and pinion gears for 20+ years and you will never get them right and to NOT make noise after they have set a wear pattern in another axle assembly but if you are ok with howling gears that's something you will have to deal with.
You can get away with using a used gear set with less than 500-800 miles on them to break-in a new wear pattern. A new set is around $200 bucks and get rid off the G80 and go with a Detroit Torsen unit. JMO of course!
RT
RT
Not to highjack this thread, but have you been able to find options for the 2014+ Silverado to go to 4.88's?
Side note, you can have my 3.42's if i can find 4.88's!
Yes 4.88 and up to 5.38 are available.
RT
Motive and Yukon has them in stock ready to ship.
RT
Thank you for that information, I will be on the phone today!
Do you have a personal opinion on the better company? I have always used G2 or Ford Performance when I was on the dark side...lol
between the two Motive is a pretty good set. Be sure you break them in properly with light acceleration and coasting, 20-30 min drives and allow full cool down.
Ok go to ECG East Coast Gear they have your pinion set 3.73 and up. Do yourself a favor don't use motive gear set people that used complain of whining noise
go with Yukon gear set and Durable Yukon Locker I haven`t heard anybody complain yet.BTW how many miles on my new set of 3.42`s lol
If not set up properly as per manufacture specs they will all whine. Be sure to follow their set up procedures. I have seen ALL manufactures gears whine when not set up properly and without a nice break-in period. If your guy uses an impact on diff repairs please find someone else to set your gears up.
RT
RT Great advise!!!!! Now here in NJ I have to find someone to make the swap out. I have gotten $2500 price quotes parts & labor that`s just insane. I`ll just have to push the pedal a little harder that`s all..
How many miles on my new gear set????lol
  • 2 months later...
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way too big headlights (similar to a previous non-Wrangler SUV) should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crossing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
