hard start cam and crank timing raw fuel?
hey guys i have just finished rebuilding this truck cam bearings rod bearings main cap bearings all the gaskets rings oil pump all the stuff thats needs replaced at 206k mi ok heres the issue got it put together could start no cel for the cam and crank timing issue made it to local part store shut off and came out no restart pulled damper in the parking lot thought it had moved the plate behind the damper for crank sensor it did not cel was for temp sensor stuck thermostat got new thermosat lol but when i went out it would not restart got it put back together the next day got started ran like crap cel illuminated again drive 15 miles shut off to restart i had to push accellerator pedal to floor turn key to start and it will start but not idle correct choppy over fueling? smell clears up after a min or two then settles down put in gear it stalls it has been running it like this for 200 300 miles now hauled some firewood for 75 miles highway its ok just not stop go traffic economy is like 12 mpg for a 305 seems kinda horrible got better mileage about 5000 miles ago did the computer go bad and is hanging or shorting an injector to stay open yes it still has poppet valves in it not the conversion mpfi yet need some help funds are drying up fast on me need 2 vehicles to run im killing my other car i put 60k miles on my car in 2 yrs i need this truck im here in ohio around jefferson county so any help is really appreciated
