Fog Lights
I have a 04 gmc sierra 1500. I got the truck a couple months ago and it didn't come with fog lights installed. I was wondering if they come with a wiring harness or I would half to buy one?
I'd like to know the answer to this too. It looks like there is a spot for a fog light relay in my electrical compartment.
You used to be able to buy fog light kit from dealer. Included lights, wiring harness from lights to underhood fuse panel and switch. Wiring in dash and to underhood fuse panel already there. I ended up buying smoked foglights online and took the wiring and put factory terminal end on, installed into fuse block, got relay and factory switch. Everything was plug and play, looks factory from inside truck.
I bought the factory kit. Very easy and very factory look when done. Everything just plugs in minus cutting out the fog light holes. That only takes a drill and a saw. I had a reciprocating saw that worked. Took 1.5 hours with cutting out the fog light holes.
    ar0517
    ar0517
  • Who's Online   5 Members, 0 Anonymous, 628 Guests (See full list)
