2014 Sierra RCSB lowered..but...
It doesn't need a notch. And you're not hitting your bump stop; that's your shocks bottoming out. They're probably ruined at this point.
oh my bump stops are hitting. Ima need to notch it pretty SoOn though.
  • Replies 45
You shouldn't need a notch for a 6" drop. I'm not anywhere close to needing a notch and I've had my kit on for close to a year and haven't hit my bumpstops once.
I just re read that your kit came with drop shocks. Are you sure you're only 6" drop?
Yeah I'm pretty sure I'm only at 6. the kit was adjustable,the lowest being 6
What kit you have on?
I have the bell tech 3/6. Front is spindles & springs. I added the drop struts.
The rear is a flip kit with Viking da shocks.
mine has the spindles and struts. Dont have the springs. What brand drop shocks did you use?
Bell tech. I used them to firm up the front. The drop is using the spindles & springs
my front shocks are pretty firm. it's the rear that bounces too much.I've noticed I take bumps or little dips way wetter in the front then the back. I ordered a pair Belltech Street Performance shocks
When I installed my flip kit a used a plasma cutter and whacked the bumpstop bracket off of the frame and then reused the factory bumpstop (drilled and Tapped the frame) and it rides just fine. I also used the Good Belltech shocks for the 5-7 drop and didn't need the shock extenders (I hate shock extenders!)
RT
can I see A picture of your bump stops
RT
i have the mcgaughys shocks too. EXACT same issue. i heard the vikings are a 100% better shocks.
do you still have your bump stops on? An. How low are you?
4/6, short bump stops.
10502095_10203877062547992_1245657362521
    250.3k
    BryantM4
    BryantM4
  • Who's Online   3 Members, 1 Anonymous, 1,014 Guests (See full list)
