FS/FT 2014 Silverado 1500 (Pro Installz)
pacebria
This truck was built was built as a demo truck and has rarely seen sunlight. It was bought in November 2014 and been inside the shop since that day. It has various mods listed below all of which were professionally installed and prefect in every way. The truck was meticulously detailed from decontaminating paint and polishing to ceramic coating. We are very particular with all our builds and this one won't disappoint even the pickiest of buyers. Feel free to contact Brian @ Pro Installz with any questions or comments.
Currently has 450 miles on it!!!
Window Sticker $30,090
Purchase Price $24,900
Modifications $9,900
Total to build $34,800
Priced to SELL QUICK!
$33,000
- 8" Suspension Lift
Ready Lift MLS Lift
Bilstein custom 7-9" lift struts (set @ 8")
Bilstein rear shocks
- Wheels/Tires
325/50R22 Nitto Trail Grapplers
22x14 Ion 183 chrome wheels
ZERO RUBBING ISSUES
- Body
OEM Z71 grille
OEM PTM door handles
OEM PTM mirror covers
OEM PTM tailgate handle
OEM PTM fog light bumper
OEM fog light brackets
OEM fog light bezels
Carriage Works Billet Grille
Chrome Bowtie
- Color Matched Body (I-Car Gold Certified paint work)
Headlights
Grille
Bumpers Front and Rear
Handles
Mirror Covers
Tailgate handle
- LED lights
30" Rough Country Dual Row LED bar
4 Rough Country Dually Cubes
- Performace (***OPTIONAL***) $2000 EXTRA!!!The truck currently has this setup on it now but priced with factory exhaust to keep the price lower.
American Racing Long Tube Headers
4" single T304 mandrel bent stainless custom exhaust
5" Magnaflow polished stainless tip
Airraid MIT
- Factory Options
Tow Package
Bluetooth Radio
Power Windows
Power Locks
Power Mirrors
Cloth Interior
Lumbar seats
** SHIPPING IS AVAILABLE**
CALL PRO INSTALLZ FOR DETAILS
Brian Pace
270-210-8415
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
