Boycott boycott boycott
RyanbabZ71
boycotters
Cant wait for the coca cola plant in germany to close and for many people to loose their jobs all because they want to boycott american goods or for the local mc donalds (which is locally owned) to close and for the people to go broke
I dont know about people nowadays.  Just because it has an american name or otherwise doesnt mean its just made there.  To quote a funny movie line "american parts, russian parts ALL MADE IN TAIWAN"
I give you all (war boycotters out there that dont think before you boycott) the  :cool: award for the day
:chevy:
I kind of expected it.  What if they were the initial boycotters?  I bet you a lot of people here would be boycotting Germany if that was the case.
The whole current boycotting thing is stupid, period.  That goes for both sides.  Do they really think Bush gives a s*%t about what CC thinks of the war?  Probably not.  This type of boycotting is pointless because the companies are not involved in the #### war.  The reason boycotting buses worked during the civil rights movement was because the public transit people were the cause and were therefore affected by the boycott.
boycotters
Like when I went truck shopping, if I wanted an US built truck, then it would be the Toyota as it is built in Indaina.  My Chevy was made in Canada!! ???
####### GERMANS AND FRENCH.
These have to be the stupidest phucking countries.
The Germans boycott AMERICAN products.Half the stuff they buy probably comes from over here in the USA.The only thing germany exports to the USA thats anygood is cars and Jaegermeister.They have nothing else worth buying what are they going to buy now that they've boycotted the USA.
And then the French.I tell you what,they wont help us get rid of Saddam.But the USA had to help them get rid of the Germans back in the day.The French say Americans are arrogant jerks and only worry about ourselves.IF IT WASNT FOR US THEY WOULDNT EVEN STILL BE ON THIS PLANET.
And people say they are boycotting French Fries and calling them Freedom Fries.They should be Freedom Fries,the potatoes are grown in Idaho and turned into fries in another state.
dcairns
My truck (silverado) was built in indiana  :chevy:  My HOME STATE!!!
Hmmph... Well as someone else said on another forum:
"Glad to see the germans have become so 'moral.' Too bad they didnt boycott the slaughter of 6 million jews..."
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
    • It would be sold as a "kit", lights + auth/programming code.   You can resell the code to someone else, if they just buy the lights, either new or used, and they can then use the code to get them to work on their truck.
    • Apologies in advance, this is a long post, there's a lot to explain.   A friend had a 2010 Avalanche with a 5.3 (LMG) that blew the head gaskets (amount other problems). He gave me a donor motor out of a 2007 suburban (LC9). I got it all installed, and everything hooked up. Went to go start it, and it stumbled a bit at first and died a couple times, but after trying a few times it sounded like it was running very well. Went out to go get some coolant, and came back the next day.    Upon trying to start it, the truck will crank and fire normally and the RPMs will raise to around 1,200 or 1,500, sounding great, and then the RPMs will decrease and it will just die. Repeat that a dozen or two dozen times, and eventually it will fire and idle beautifully. As soon as you touch the throttle, it will start misfiring and sound like absolute trash. When you let off the throttle it will come down and hunt around shaking and misfiring like crazy. A message will come up on the dash saying reduced engine power.    It is throwing codes for a map sensor circuit voltage High, as well as MAF sensor low frequency. With key on engine off, the map sensor reads about 4.8 volts on the vout pin, which the PCM interprets as about 17.8 PSI, contrasted to the barometer which my scan tool tells me reads about 13.5 PSI. However, once the engine starts and is idling this reading drops to about 5-6 PSI at a stable idle, and varies significantly when the engine is misfiring/ hunting like I said before. I should note that I used the intake and MAP sensor from the LC9 engine. I changed the connector on the 2010 harness to The 2007 connector. The pinouts for the sensors were printed right on the top, and I triple-checked that I put the correct wire into the correct place.   On the other hand, the MAF sensor reads consistently 0.0 g/s regardless of State. I have pulled my hair out trying to figure out this last detail. I have tried three different sensors, (all of which should be good, one of which was new), I have verified all the wiring from the sensor going back to the PCM, and have verified that the readings at the PCM are the same readings as at the sensor itself. The intake air temperature sensor is also functioning as normal. I verified all the voltages and grounds etc, and everything is as it should be. I don't have an oscilloscope to verify, but I probed with my multimeter (Klein mm720) on frequency Mode, and it reads that on initial cranking, the maf is producing between 3000 and 7000 HZ, and as soon as the engine fires that falls off to below, 1000, and if the engine continues to run, it will produce somewhat erratic readings between 5 and 100-200 HZ. It does increase notably when the engine is revved despite the misfirings. As I said before, I have verified all of the wires going to the PCM, and I have tried multiple known good sensors. I've tested all the pins and voltages from the sensor and verified them against the manual that they are what they should be. I tested all the wiring for both ohms and voltage drop, and everything tested fine. Like I said I tested at the sensor as well as right at the PCM, everything checked out.   The only other thing of note at least I think is the fact that the engine originally in the truck had VVT, but the engine I put in, the lc9, does not have VVT. I modified the cam sensor plug to work. I reference the wiring diagrams and double-checked that I modified the harness correctly to adapt it. There is obviously a code for the VVT solenoid, but I don't think that's the cause of my problems, and this friend will probably have the PCM sent off to tune out the codes at some point.   I'm writing this for my bed so I don't recall the exact codes, but I'll update the post tomorrow morning with the exact codes. And ideas or feedback much appreciated.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
