rear window squeak
I have a 2014 LT Silverado with the solid rear window. I've been noticing a squeak every time I hit a bump at first I thought it was the rear seat but I closed the rear door and heard it. after figuring that out I realized it was the rear window. Do you think ice could of loosen something or the glass isn't installed right. It has been -20 to -35 the past couple weeks but I'm not sure if that's the cause. anyone else have this problem.
A chunk of ice/snow hanging between the box and the back of the cab will cause a similar noise.
Nope no ice I brought it in our shop and everything melted off . If I tap the rear window it makes the noise it's really annoying.
I have a 2014 Silverado LT, RC and noticed a similar squeak from the rear window not long after bought the truck. A very small piece of foam weatherstripping wedged in between the bottom of the window and the big plastic back (inside the cab) cured that squeak.
And I've been hoping mine would quit squeaking when it warmed up....
