Spring SoCal meet?
Spurshot
Anybody meeting up close to San Diego area??
We dont have a huge member base there. We have quite a few in LA and cental cal. The last one at Castaic, a guy drove his Silverado SS from Paso Robles.
Are you still planning on Castaic, Chris?
Where is everyone from around here? Might as well meet close to where most people live.
I'm in the LA area myself for what it's worth.
Castaic has seemed to be fairly central for the group with me and 1 other guy from Bakersfield making the longest drive
  • 1 month later...
I was going to ask you guys so i can finalize it. There will be a banner and possibly a 12x12 canopy. Company invested in us
We had a small turnout today at Castaic, but we shot the bull and met new friends.
Love the pics Chuck :thumbs: Had a great time today meeting you guys(& girl :) ).
Wonder how long it took Chris to get home,if he's even home by now :dunno:
I got home around 5:40. I passed both of you on lake hughes after i turned around. I took Ridge Rte back
    Fishboat
    Fishboat
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
