JBL P660c
So I just bought a pair of JBL p660c Components, they should get here by Wednesday and I'll have them on by Friday if not Saturday. they are 6.5 speaker, that's not what worries me. what does is I don't know where to place the tweeters. Can I put them in the dash Where the factory ones are? Will they fit? Or am I going to have to go custom. Let me remind you my truck is a regular cab with the 6 speaker option.
Any good amp will work, but it does require significant rewiring, of course. I think you might be well served by taking the truck to a good stereo shop and getting an estimate from them. Without a back seat, I do not know what might fit and where.
why do you say that?
You need to bring high level wires to amp, convert to line level then send new speaker wires from amp to speakers. Plus run amp power.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
