DIY spray in bed liner??
So who here has done there own and did you get good results? How well is the coating standing up to abuse? Did you spray it on or roller and a brush? Which product seems to be the best for the DIY bedliner?
Looking to do mine this year and I'm hoping to learn from everyone else's experience before choose the right brand.
I used Scorpion. Dine by a friend and i. We sprayed. Came out great. Runs about $200 or $250 for the 2 gallon kit and gun. It is tacky and has held up to the abuse ive put it through
Just order it directly from Scorpion. All you need is an air compressor that you can regulate to about 20-30 psi. A drill and bucket to mix, and they offer a nylon cup brush to do the prep. I also used an 80 grit sanding sponge for corners. I also added the optional metal flake to it. It is easy to mix and spray yourself. If any gets on the truck it can be cleaned with denatured alcohol.
    Aries68
    Aries68
  • Who's Online   1 Member, 0 Anonymous, 285 Guests (See full list)
