99 5.3 4l60e to 99 5.7 engine
Ok I was changing a transmission for my Pastor because his was beyond rebuilding and he went and picked up a transmission out of another 99 4x4 as it turns out the one he picked up will not work it came out of a 5.3 he has a 5.7 Is there an adapter kit out there for this swap?
Ok after no replies here I explored my options elsewhere and found a transmission adapter kit from JEGS that is suppoesd work part #809-19154766 In case anyone else runs into this unexpected Problem.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
