blue granite metallic touch up paint
I have a couple small nicks on my 2014 Silverado. Blue Granite Metallic, can anyone point me in the right direction to a bottle of the touch up paint? I can't seem to find any when searching the internet. I've seen where Stealth Grey is supposedly not the same as the Blue Granite. Thanks.
