xpel sierra
Just bought a 2015 Sierra 1500 Denali. Currently trying not to go too broke adding accessories. Ive got an appointment next week to have Xpel protective film put on. Currently looking at having the front bumper (upper and lower) done. I also had them price doing the grill, but after thinking about it, not sure if it's necessary? What are others thoughts? Instead of the grill, should I do the headlights and hood? 1200 miles and I already have a paint chip on bumper, which infuriates me to say the least. Any tips or thoughts are appreciated.
They don't use epoxy primer on the bumpers and they chip incredibly easy! I test drove a demo before buying mine that had 7000km on it and the bumper was chipped really bad. Definitely do the bumper, but I cant recall there being many chips on the rest of the front end. When I had mine painted the guy who does my body work told me he was using an epoxy primer and it shouldn't chip as easy as the do from the factory. I also talked to a mechanic at my local dealership and he said he would never buy factory painted bumpers because of how many he has seen come back chipped.
yea, they just look so damn good though. I read the same thing about the paint, so hopefully the expel might prevent it.
I'm going to try my hand at installing the 3M Pro stuff. Lower bumper, leading edge of hood, fenders and cab. A pillers, door handle pockets, mirrors and head lights. These are rock chip targets.
Burner,
I'm in Houston, too. Who did you procure to do your Xpel film? I also have a 2015 Denali with only 1200 miles on it and it's lifted 8" on 35's and I've still managed to get 3-4 chips already in the bumper. I would have thought sitting so much higher it would dodge most, but not enough I guess. Might I ask what they quoted you to do the bumper?
597AA1FA-DF19-4B4E-88E6-E9E933D92C46_zps
That's not horrible as I can imagine that bumper is a pain to iron out the bubbles and wrinkles on. And I don't see the need to do my grille. Once I adjusted the magnetic ride control sensors up front, if I put you in it and told you to close your eyes, I bet you wouldn't even be able to tell it's lifted. Other than a little effect of the heavier wheels and tires resulting in additional unsprung weight, which is minimal at best, it rides like the day I bought it. Still gets out of the gate like a monster and maintains an average of 16mpg with the 6.2L and 3:42 gears turning 20x10 wheels and 35x12.50 tires.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 423 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
