2015 Silverado Bed Cover
Hey guys I read some stuff on the Bakflip G2 but I am looking at the Undercover Flex. Anybody have this one? What's the pros and cons of it over others? THANKS
Installed a undercover last week. I like it a lot. Not sure if I will get any water. Install was easy but had to do adjustments that required redrilling all the latches to get a perfect fit. Also waiting for some hot sunny weather to make the seals form to the side rails better. I could probably take a hair dryer to it also. Folding it is easy with one hand. So far so good.
Can you show me how you routed your drain tube on the passenger side? My truck has the factory bed liner and only a large hole on the driver side and a few small holes across the front. No matching larger hole on the passenger side to fit the drain tube into.
I also just installed the flex on my truck. I liked the longer warranty, fit and finish when I viewed them on friends trucks, and definitely didn't want a cover that contacted the cab of the truck. My last soft tonneau would leave fine scratches when it was up against the cab.
Sent from my HTC One using Tapatalk
I purchased a black pvc barb fitting at the hardware store. Not sure the size . It fit in the supplied grain hose and the other end in the last hole on the passenger side.
I have had both covers and I prefer the undercover, it's sturdier and keeps out more rain the the backflip
The install was also easier for the undercover
