Vibration at 70 to 80
I have an 04 2500 hd 6.0 135000 miles that has a vibration at highway speeds mostly 75 on the gas it vibrates if you let off it goes away until the tranny starts to slow the truck down it comes back. I've balanced the tires rotated had the drive shaft balanced no change. I replaced the granny mount and it got a little better but it's still there. Today coming home long highway run I noticed the tranny temps were almost 200 which is not normal. Could it be the torque converter causing it. Tranny been serviced was just done 10 k ago but switched to the new dextron could the high temps be from that should I go back to Dex 3
With regard to the vibration, take it to a reputable tire shop and tell them you are chasing a vibration issue that you think is related to the wheel balance or maybe related to a wheel with runout issues. Ask them to have the most experienced tire tech do the balance and ask if you can go in the shop with them while the tire is being balanced so you can watch. When the tech mounts the wheel on the balancer, both of you watch closely for abnormal runout while the tire is spinning. An experienced tech will be able to spot any abnormal problems. Let him balance it as he normally would and then when one wheel is complete, ask him if he will take the wheel off of the balancer completely, then put it right back on and check the balance again. he will look funny at you but insist he do it. Don't be surprised to see the just balanced wheel is now out of balance. It may take the tech two or even three tries to get the tire to balance properly when checked this way. This is particularly true if you have aftermarket rims, but it also applies to regular factory wheels too. Hunter machines do ok on smaller tires but for larger truck tires, it sometimes takes a few tries to get it right. My new to me 2010 2500HD suffered from this and this was the cure.
When the tech remounts the wheels on the truck, the two of you can then look for worn ball joints and if 4wd, asses the condition of the unit hubs.
If you still have issues after this, you've eliminated the tires and wheels as being the issue.
    mark2
    mark2
  • Who's Online   4 Members, 0 Anonymous, 581 Guests (See full list)
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
