High Country Mods
I have made a few additions to my new truck, nothing radical... On top of the mods below, I also did the diode mod on the fog lights and a set of black bowties should be here tomorrow.
  • Undercover Flex - Very straight forward and easy installation with a great fit.
  • AVS Hoodflector - Simple installation and an excellent fit, just what I was looking for. Please excuse the "finger in photo pic...lol!
  • Lund 5" Steps - Easy install - I only installed these for my 5'2" wife...lol. They are cheap, in cost and construction (plastic chrome), but very sturdy.
Didn't your High Country come with the rectangular factory steps?
They were standard on my '15 HC. The factory steps are nice, but I wish they were black instead of chrome as I'm trying to eliminate most of the side chrome on the truck. So far painted mirror covers and door handles, black window sill trim, and removed the side HC badges. I have a set of painted body side molding but haven't gotten around to putting it on yet.
I would really like to get black factory steps and some black OEM 5-spoke wheels, but this is a much larger dollar investment than just the trim pieces.
For the 2014's, the steps and spray in bed liner were options. If the truck was any color but black, I would probably de-chrome it a bit more, but this old dude likes a little chrome on black. Now if Cragar Wheels would go back to making the chrome SST Super Tricks..... :)
  • 1 year later...
Patrick, pix will not pull up. Would you mind reposting? I have a 14 black high country. Looking to mod it.
HC is a good looking truck . BUT BROWN leather - no thank you .
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 692 Guests (See full list)
