Mirror light upgrades
I'm looking for an upgrade to the outside mirror entry lights? Have any of you seen something that might work?
I was under the impression that they're not swapable? I will take a look into it more tonight because I would stick some cree's in there if I could.
I saw someone on a GMT-900 install some Rigid Industries A-series lights under their mirror and it was really bright. Might look into that route.
