Speed Limiter
I am looking for a way to disable / remove the speed limiter of 98MPH on my truck. Its not that I want to go that fast all the time or have yet, but its the feeling that knowing that its there and I can't do anything about it. Does anyone know how to fix this without buying a 300+ dollar tuner. I have the 2015 silverado lt Z71, 5.3 motor 6 speed trans. Has to be something out!!
I'm sure it wouldn't hurt to get rid of that very very very annoying pedal lag either...
