My first tow...
A refresher - 2014 Silverado HC Crew Cab, Short Bed w/6.2 with 4,500 miles - My trailer is a 24' Carson Funrunner weighing 5,300# dry (800# tongue weight)- I had a HD Fat Bob in it and the water tanks were all dry. I was thoroughly impressed, I had towed this trailer in the past with a 2000 LS with the 285hp 5.3 and a 3:42....It struggled with power and the weight before on anything other than flat land. Though todays' trip was only 25 miles, the truck is a BEAST! And the trailer brake controller was as good or better than any aftermarket unit I've used. In August I will drag it up to Knoxville, IA (1420 mile roundtrip), and I am anxious to see how it does.
They do pull good. Lat weekend I pulled a 20 foot car hauler with a lifted jeep and two utility quads over 400 miles no problem. Everything on the scales put us at just over 14,500lbs and it was a joy too pull. 5.3 3.42 crew standard box 4x4.
Here is a pic of the rig, it's leveled out pretty good, next time I will grab one more link on the load bars and I am thinking about coming up one hole on the hitch. The weight isn't an issue, but the wind drag definitely a factor. I consistently got 9.6 mpg in the "open air"....Hanging back 50 yards behind a semi got me to 12 to 13mpg....all at 65mph.
Hard to be 100% based on the picture, but I wouldn't grab another link on the chain. Already the bars are passed parallel which, depending on the manufacturer, is wrong. They should be parallel. Your trailer is sitting pretty level so I wouldn't adjust the height of the ball either. I would add some tilt to the hitch head. Start with one or maybe two extra washers.
I was in the same boat but after a couple hours at a scale when it was closed on a Sunday I nailed it with just the head tilt.
Sent from my SM-N900W8 using Tapatalk
According to the MFG (Draw-Tite), I can take the bars to link #6, right now I'm at link #7. The ball is tilted a few degrees back as it sits...I need to spend a little more time with it to fine tune it...
Hope I'm not hijacking here. But I'm in the market for a toy hauler and I'm curious about the Fun Runners. I'd be loading a side by side in it. What are the garage dimensions for yours and do you think an Arcitc Cat Wildcat X 1000 will squeeze in there at almost 60"W x 10'L x 5'8"H?
No worries, I don't have the exact dimensions for this, but any side by side would fit just fine with room to spare. This is an older one (2001) and it has held up pretty well considering it has always been stored in the open air. It is 24' long and wider than my truck.
Sounds like it would work. I'm looking for a used unit as it's only outings will be to offroad parks and will get some dirt in/on it. So there's no way I could bring myself to pay new prices for one and then stab my muddy side by side off in it for the ride home. Thanks for the info!
I'd recommend a bit of caution and encourage you to go to scales, or at the very least use careful measurements of your front fender height to set up the hitch. You can't completely level the truck with the hitch--that's way too much adjustment. GM says to use 50% FRONT AXLE LOAD RESTORATION, I wouldn't recommend going much over that. Your trailer is light enough your handling should be fine anywhere in the 50%-100% range, there's no need to overdo it. If you want it more level than that gets you, a set of airbags is a great help.
There will be a heck of a deal on this one when I get back from a trip in mid August....
As a Class "A" CDL holder for over 30 years, (and I used it for quite a few of those) and based off the hitch manufacturer's recommendations, I'm pretty confident in the way it is configured, sans a possible slight ball angle adjustment.
Perfect. PM me when you're ready. I'm gonna wait till later in the year anyway. And I'm in Houston, so I can come get it.
Perfect. See, different brands and setups call for different things. Sounds like you know what you're doing and have done the research you need.
Well, alrighty then. Carry on.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
