Anyone recommend a rack that could drop in the stake bed holes?
Not sure if there are 4 or 6 stake bed hole covers that can be cut out to gain access to the pockets.
I cut out access to the two front ones and am using them for antennas.
Is there some upside down U shaped frame that would drop in to two opposite holes to use as a rack (if using two)??
I'm guessing there must be because there wouldn't be much other use for those holes.
Ladders and Kayaks etc are moved only occasionally, so if racks were removable (lift out) I could keep the racks in the garage....problem would be solved.
Maybe I can just make some?
Suggestions?
I haven't seen a set yet. But the GM track system that attaches to the inside of the bed had an overhead rack attachment.
  • 3 weeks later...
I've been eyeing some Thule roof rack and bed mounted options as well as Yakima. Did you ever find a solution Op?
-Skeet
    appletrav
    appletrav
  • Who's Online   0 Members, 0 Anonymous, 286 Guests (See full list)
