2014 power passenger seat add on?
My truck has a standard passenger seat. My wife is short and says she sits too low, I would like to install a 6 way power seat for her. Is this as simple as adding the hardware to the existing seat? And is the wiring in the truck for this modification. Anyone done this?
I think there is a seat block you can install, might be an easier and more eco solution. it raises the entire seat up.
Is this a GM or aftermarket part? do you know where to find one?
I am sorry, I have only merely saw a random post a while back that his seat is not powered but that helped his line of sight after he had it installed.
Maybe make a few blocks and longer bolts could do the same thing
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 234 Guests (See full list)
